Interface Bureau
Répondre
Gamme Aura
07 Nov 2010 à 12:07
Certains d'entre nous ne tarrissent plus d'éloges pour les amplis Aura.
Je me suis donc penché sur la gamme de produits de la défunte marque :
Aura VA40
Integrated Amplifier
Specification unknown
Front Panel: Soft black
Aura VA50
Inputs: Phono, CD, Tuner, Line 1, Line 2, Tape
Power Output: 50W RMS Per Channel into 8 Ohms @ 1kHz
Peak Current: Programme related IHF, +/- 11A
Total Harmonic Distortion: <0.05% at rated power, 1kHz
Input Overload: Phono >25dB IHF, Line >25dB IHF
Separation: >60dB at 1kHz
Input Sensitivity: 220mV, 50k Ohms
Front Panel: Chrome or Mirror Black
Aura VA80
Inputs: CD, Tuner, Line 1, Line 2, Line 3, Tape
Power Output: 45W RMS Per Channel into 8 Ohms @ 1kHz
Total Harmonic Distortion: 0.01% at 1kHz (unweighted)
Signal/Noise Ratio: -95dB (weighted)
Dimensions (WxDxH): 430x310x62 (mm)
Weight: 4.7kg packed
Original Retail Price - £320 (Chrome Front), £280 (Black Mirror)
Aura VA80 SE-X
Inputs: Phono, CD, Tuner, Line 1, Line 2, Line 3, Tape
Signal/Noise Ratio: 76dBA (Phono), -95dB (weighted, lines)
Comments : gold plated speaker plugs
Aura VA100 Evolution
Signal/Noise Ratio (Ref. Rated Power): 76dBA (Phono), 96dB (Aux)
Aura VA100 mk II Evolution
Inputs: Phono,CD, Tuner, Line 1, Line 2, Tape
Power Output: 66W RMS Per Channel into 8 Ohms @ 1kHz
Total Harmonic Distortion: <0.03% (10Hz-20kHz)
Balance: < +/- 0.5dB
Phono Bandwidth: 15Hz-20kHz (-3dB, RIAA)
Original Retail Price - £400 (Chrome Front), £350 (Black Mirror)
Aura VA150
Power Output: 100W RMS Per Channel into 8 Ohms @ 1kHz
Total Harmonic Distortion: <0.01% (1kHz)
Dimensions (WxDxH): 430x340x75 (mm)
Weight: 9kg packed
Original Retail Price - £850 (Chrome Front), £800 (Black Mirror)
Comments - Gold links combine Pre and Power stages, has Power Out to Bi-Amp with PA100 or act as a pre-amp.
Service Manual du Aura VA 150, Mis à disposition par philoucmoi  : http://teloniourf.free.fr/AuraVA150.pdf
Aura CA200
Pre Amplifier
Inputs: Phono/Line1, Line 2 - Line 8, Tape 1, Tape 2
Outputs: Unbalanced (two sets), True balanced XLR
Total Harmonic Distortion: <0.001% (ref 0dB, 1kHz)
Dimensions (WxDxH): 430x340x62 (mm)
Weight: 5kg packed
Original Retail Price - £750 (Chrome Front), £700 (Black Mirror)
Comments - Dual Pure 'Class A' design (Pre-amplifier and headphone sections). The Remote Control was designed by Kenneth Grange (Designer of the B&W Matrix series).
HiFiWord March 97 : A smooth and sweet sound devoid of roughness.
Aura PA100
Power Amplifier
Inputs: Unbalanced
Input Sensitivity: 1V RMS per channel
Power Output: 100W RMS per channel into 8 Ohms @ 1kHz, 250W RMS Bridged
Total Harmonic Distortion: <0.01% @ 1kHz
Weight: 9kg packed
Comments - Uses same Power transistors as the Integrated Amplifiers but six per channel. Circuit Layout is essentially the same as the VA150.
HifiWord March 97 : A smooth, sweet powerful sound free from the rough brightness that afflicts many solid-states.
Aura PA200
Power Amplifier
Inputs: Unbalanced, True balanced XLR
Input Sensitivity: 1V RMS, unbalanced 20k Ohms
Power Output: 110W RMS per channel into 8 Ohms @ 1kHz (250W RMS Bridged)
Total Harmonic Distortion: <0.003% (1kHz)
Residual Output Noise: < -102 dB (unweighted, ref 100W)
Dimensions (WxDxH): 430x340x105 (mm)
Weight: 15kg packed
Original Retail Price - £1250 (Chrome Front), £1200 (Black Mirror)
Comments - Features a completely different design compared to the other amplifiers, the top of the amplifer is actually a heatsink and the circle section is the massive potted torroid transformer.
Aura TU80
Tuner
Antenna Input Impedance: 75 Ohms (FM) / 300 Ohms (AM)
Audio Output: 600mV RMS
Ultimate S/N Ratio: >60 dB (100% mod)
Stereo Separation: >39 dB
Audio Bandwidth: 10Hz - 15kHz +/- 0.5dB
Dimensions (WxDxH): 430 x 295 x 62 (mm)
Weight: 4.0kg Packed
Aura CD50
CD Player
Transport: CDM 9
Signal To Noise: 98.2dB
D/A Conversion: Philips SAA7321 Bit Stream DAC with Burr Brown OpAmps
Digital Output: Coaxial
Total Harmonic Distortion: -95.1dB @ 0dB, 1kHz
Comments - Aura has devised its own in-house servo board and modifications for the analogue output stage. The technical fingerprint of the player is little different from any other Philips 600 series derivation however.
Aura CD100
CD Player
Transport: CDM 12.4 (Triple Beam Mechanism)
D/A Conversion: Continuous Calibration Multibit/Bitstream
Analogue Output: 2.0v RMS @ 0dB
Digital Output: 75 Ohms Coaxial
Total Harmonic Distortion: -85dB @ 0dB, 1kHz
Frequency Response: 20Hz-20kHz +/- 0.2dB (ref. 0dB, 1kHz)
Dimensions (WxDxH): 430x280x62 (mm)
Weight: 4.4kg packed
Avis aux amateurs ;)
Re: Gamme Aura
30 Jan 2011 à 17:02
bonjour, je n'avais pas vu ce fil, belle présentation de la gamme ; j'aime le côté épuré des appareils, aussi le fait qu'il y ait une continuité dans l'esthétique
quels appareils as-tu écoutés, même possédés, et que pourrais-tu en dire ?  :tongue:
Re: Gamme Aura
02 Fév 2011 à 17:57
Coté ampli j'ai eu un VA50, un VA80-SEX, et j'ai un VA100.. Des trois, c'est el VA80-SE-X que j'ai préféré. Un très bon appareil. Je suis en train de remplacer le VA100, qui a besoin d'une bonne révision, et qui sera ensuite à vendre. Ce qui frappe le plus, c'est qu'ils sont homogènes et volontaires. Y compris quand utilisés sur des tannoy DC, réputées consommatrices de courant.
J'ai aussi eu le tuner TU80 et le lecteur CD100 (dont j'ai upgradé la partie DAC). Deux appareils tout à fait valables.
Ce sont globalement de bons appareils, qui présentent bien pour un prix modique. La qualité est satisfaisante, bien qu'on puisse regretter la construction "grande série" : chassis tôle etc. Mais aussi c'est ce qui leur a permis de sortir à un bon tarif.
Le VA100mk1 et le VA150 sont apparemment plus fragiles que les VA50, VA80 et VA100mk2.
Re: Gamme Aura
15 Fév 2011 à 22:21
bonjour MC911. Belle présentation de la gamme. Pour le VA100, à quel autre ampli pourrait-tu comparer son rendu ?
Re: Gamme Aura
16 Fév 2011 à 00:18
Difficile de comparer son rendu. Disons que j'ai eu d'autres amplis (audio analogue Puccini SE Remote puis une paire de Quad 405-2 upgradé/bridgés) ... et que le VA100 est plus neutre. J'ai trouvé les Quad plus descendants et plus ronds, mais moins précis. Et le Puccini manquait de dynamisme (mais ses concepteurs disent avoir voulu lui conférer une sonorité tube ...).
Comme ce sont des appareils qu'on trouve à relativement bon marché, mais qui ne décotent plus le mieux pour te faire une idée est peut-être d'en adopter un (ne serait-ce que momentanément) ...
Re: Gamme Aura
16 Fév 2011 à 18:32
merci. J'ai aussi possédé un puccini SE, donc ça me donne une idée plus précise. Je pensais quand même que l'Aura avait une sonorité proche des amplis à tubes.
Re: Gamme Aura
16 Fév 2011 à 18:50
olicox a écrit:merci. J'ai aussi possédé un puccini SE, donc ça me donne une idée plus précise. Je pensais quand même que l'Aura avait une sonorité proche des amplis à tubes.
Bin si tube pour toi veut dire bouché et mou (comme le puccini), un VA 100 n'a rien a voir , maintenant le tube ,le vrai , c'est plein de vie , une image sonore grandiose , un aigu pétillant et j'en passe alors là oui l'Aura est proche de ce tube là  :wink:
Chris
Re: Gamme Aura
16 Fév 2011 à 19:05
Bonjour Pépi, tu as eu l'occasion d'en écouter ? Dans quelle configuration ? Qu'en penses- tu ? Bon allez j'avoue, j'en ai réservé un d'occasion et je suis impatient d'en savoir plus.
Re: Gamme Aura
20 Mar 2011 à 12:57
olicox » 16 Fév 2011 à 17:32 a écrit:merci. J'ai aussi possédé un puccini SE, donc ça me donne une idée plus précise. Je pensais quand même que l'Aura avait une sonorité proche des amplis à tubes.
Perso je dirais qu'il y a déjà une grosse différence de sonorité entre le VA80 et le VA100.
Le VA80 est beaucoup plus tube au point qu'un ami m'a demandé de transformer son VA100 en VA80, ce que j'ai fait en transformant l'alim de VA100 en VA80 + qques changements de résistances en sortie. Et cela a (semble-t-il) marché car il ne jure plus que par son VA100 modifié avec ses clones de ProAc 2.5 :biggrin:
Mais maintenant cela fait plus de 10 ans ...
Re: Gamme Aura
21 Mar 2011 à 11:06
olicox » 16 Fév 2011, 19:05 a écrit:Bonjour Pépi, tu as eu l'occasion d'en écouter ? Dans quelle configuration ? Qu'en penses- tu ? Bon allez j'avoue, j'en ai réservé un d'occasion et je suis impatient d'en savoir plus.
Oula désolé je n'avais pas vu ton post  :redface:
Oui j'ai écouté et possédé un ampli de la marque Aura ....
Ma première écoute chez un ami , un VA 50 avec des biblio Tannoy et un lecteur cd Nakamichi , tellement superbe que dans les mois qui ont suivi , le temps d'économiser et je me payais un VA 100 Evolution fallait que je fasse mieux que mon ami  non mais  :cheesygrin:
Il est passé pas mal de matériel en tout genre de part chez moi , et bien que n'ayant pas l'habitude de regretter quoi que ce soit , et a par une piéce dédiée dans une de mes ex maisons (pour ça aussi j'ai la changite  :mrgreen: ),  s'il y a bien un système dont je pourrais reparler avec nostalgie c'est bien celui dont le coeur était le VA 100 , a l'époque associé a des MULIDINE Arcade et un lecteur ARCAM Alpha One ......
Chris
Re: Gamme Aura
21 Mar 2011 à 11:17
Finnigan67 » 20 Mar 2011, 12:57 a écrit:Perso je dirais qu'il y a déjà une grosse différence de sonorité entre le VA80 et le VA100.
Grosse différence, c'est beaucoup dire. J'ai moi aussi préféré mon VA80SE-X au VA100 ... mais vu que je n'ai pas eu les deux à dispo en même temps, je me suis toujours demandé si c'était une préférence objective ou subjective.
Re: Gamme Aura
21 Mar 2011 à 19:30
J'ai le mien depuis plusieurs semaines maintenant et je dois avouer que j'adore sa sonorité, faite à la fois de douceur et de timbres justes, avec un médium bien présent. Bien que j'ai l'impression qu'il ouvre plus sur la voie de droite. Une bonne révision ne lui ferait pas de mal.
Re: Gamme Aura
21 Mar 2011 à 19:51
comme tu peux le voir dans le post viewtopic.php?f=17&t=1585, nos petits aura ont parfois des soucis en vieillissant. Ramesh, un ancien de chez aura assure (enfin j'ai pas eu de nouvelles depuis genre 3 ans) encore un peu de maintenance, et dispose de pas mal de pièces genre façades ou mécaniques CD. cf viewtopic.php?f=12&t=1685&p=56731#p56731
Re: Gamme Aura
26 Mar 2011 à 11:14
J'ai comparé les deux pendant plus d'une semaine avec mon Arcam Delta 270 et mes ProAc Studio 200 et franchement le VA80 avait des basses beaucoup plus présentes et globalement beaucoup plus de présence probablement au détriment de la neutralité, mais j'aimais bien.
Re: Gamme Aura
18 Fév 2013 à 00:35
J’ai un excellent lecteur AURA CD50 façade chrome, dont le tiroir fait des siennes : il ne veut plus se refermer électriquement !!
Habitant à Tahiti, je n’ai personne sous la main pour y remédier, au milieu du Pacifique et la tête en bas .
Bref, s’il intéresse quelqu’un « dans son jus », je le cèderais volontiers à toute personne qui me ferait une offre raisonnable en MP.
Expédition à ma charge, possible au départ de France métropolitaine à partir de début mars.
:cool:
Re: Gamme Aura
01 Avr 2017 à 14:54
Quelqu'un a t il déjà pu comparer un Aura avec un Qed ex: qed 240cd ou 240 SA ou le combo C300/P300?
Musicman
Re: Gamme Aura
01 Avr 2017 à 22:51
Beau déterrage de topic ;-)
Malheureusement je ne peux pas te répondre. Pas eu l'occasion de tester les qed.
J'espère que quelqu'un pourra te répondre
Re: Gamme Aura
01 Avr 2017 à 22:58
Pas moi ... mon CD50, il y a belle lurette qu'il est parti à la benne ... me reste bien un VA50 noir ... s'il intéresse quelqu'un ... avant de finir lui aussi à la benne ...  :neutral:
Re: Gamme Aura
01 Avr 2017 à 23:07
Ce serait dommage de le jeter... ça peut toujours servir d'appoint, rendre service à un gamin...
Je dis ça, car quand j'ai voulu faire réparer / retuber mon Sonic Frontiers, le gars qui l'a pris en charge me l'a gardé deux mois. J'étais bien content de pouvoir ressortir mon Aura de sa remise ;-)
Re: Gamme Aura
01 Avr 2017 à 23:50
C'est qu'étant en full Naim ... et avec 3 systèmes ... l'Aura ne me serait d'aucun secours ... question de connectique ...  :wink:
Répondre
